pulling the motor...
Find two bolts some were on opposite sides of the block and take them out then take the chain from the cherry picker and put the bolts threw 2 links of the chain and put a washer on the end now screw the bolts back in and lift away
The way the Helms manual recommends is to bolt one end of the chain to a 10mm threaded boss on the drivers side rear of the head and the other end to a metal flange bolted to the bell housing above the clutch cylinder. This is the way i've always done it.
Mike
Mike
shermanyang
Mar 29, 2003 11:02 PM
