wiring pins...searched but nothing..
Old 12-26-2002, 12:24 PM
Mad Scientist
mmuller's Avatar
Default wiring pins...searched but nothing..
how do pin the wires(for vtec)to the ecu plug? i was looking at it do i need to get the pins and then pin them...or...
where do i get the pins?
Old 12-26-2002, 01:03 PM
Mad Scientist
mmuller's Avatar
Default Re: wiring pins...searched but nothing.. (mmuller)
ttt
Old 12-26-2002, 06:17 PM
Chiclets's Avatar
junkyard
Old 12-27-2002, 05:30 AM
VTECVillain's Avatar
Default Re: wiring pins...searched but nothing.. (proud BLACK honda owner)
Get to a junkyard and cut off the inside ECU plugs and as much wire as you can. I use a sewing machine needle to remove the pins from the plugs. You could break the plugs open to get them out, but you'll need to learn to repin them when you start adding wires to your stock ECU plugs.
dfoxengr
07-13-2008 11:49 AM
WCI
11-09-2003 08:17 PM
DR. ON POINT
03-20-2002 06:32 PM
B18C-EJ1
02-01-2002 12:35 AM
HX_Guy
09-13-2001 02:43 PM
Quick Reply: wiring pins...searched but nothing..
