ECU help!
Old Feb 23, 2003 | 01:50 PM
Neechert's Avatar
Default ECU help!
OKAY, im swapping a b16a2 with web cams and CTR pistons into my 6th gen EX. Whats the best option for ECUs since i have the higher CR and better cams? Does the stock p28 work with the b16, or do i have to go hondata with the p28? Could i just run a p30 with a VAFC?? WHERE DO I GET A P30 I CANT FIND THEM ANYWHERE!!!!
Old Feb 23, 2003 | 02:14 PM
eg6ajk's Avatar
Default Re: ECU help! (N2oCeeVick)
to run a OBDI ecu you will need a harness converter first
you can run a chipped P08/P28/P91 (check my sig), this way you get fuel maps, revlimit that suits your needs. other choice is is to use a JDM P30/PCT/P73 OBDII 96-8 ecu
p30 are rather rare and pricey.
Old Feb 23, 2003 | 09:24 PM
Neechert's Avatar
Default Re: ECU help! (eg6ajk)
yeah, know about that whole conversion thing. HONDATA sells p28s with obd2 connectors built into them, and was wondering if you HAVE to go hondata to put that on a b16. Another question; is it possible to run a 99 and up obd2 ECU on a 96 obd2 wiring harness, since there is a difference?
[Modified by N2oCeeVick, 11:25 PM 2/23/2003]
StRoKeD-B16bEj2
Nov 22, 2005 07:32 PM
SuperImport
Apr 16, 2005 04:22 PM
B00ST2nR
Mar 12, 2003 06:21 AM
DohcRex
Feb 9, 2003 02:53 PM
