need help with broken engine mount
Old Feb 23, 2003 | 01:40 AM
vsi's Avatar
vsi
Default need help with broken engine mount
i have an eg hatch with a h22 swapped in and i broke the rear engine mount, i crawled under there today to pull it out and the mount is snapped in two. one of the rear bolts is broken off and is still in the hole on the subframe and the other is gone. my question is are the holes in the subframe threaded(bolts go down into the subframe) or do the bolts come up out of the subframe? any help or advice is greatly appreciated.
Old Feb 23, 2003 | 03:01 PM
vsi's Avatar
vsi
Default Re: need help with broken engine mount (vsi)
ttt
Old Feb 23, 2003 | 04:20 PM
KENLUDE97's Avatar
The only thing that i can tell you is to get ahold of the bolt with a pair of Vise grips and turn? And if you can not get ahold of the bolt then drill it out... and if that is not possible weld the mount on the sub frame... that is the last resort but a option....
birdricer
May 17, 2007 05:03 PM
GapxGuy
Welding / Fabrication
Aug 25, 2004 07:39 AM
GapxGuy
Aug 24, 2004 09:41 PM
Trbospnkr
Feb 8, 2004 02:05 PM
CristalCleanCivic 97 EX
Aug 8, 2003 10:39 AM
