Kenji !!! need your help
Old Feb 24, 2003 | 05:06 PM
khang77642's Avatar
Default Kenji !!! need your help
Hey kenji the chipped p28 ECU that I bought from you, do I have to wire up the knock sensor for the b16?
Old Feb 24, 2003 | 05:34 PM
eg6ajk's Avatar
Default Re: Kenji !!! need your help (khang77642)
no P28 do not use a knock sensor input. so there is no need in wiring it up.
Old Feb 24, 2003 | 08:16 PM
poison's Avatar
Default Re: Kenji !!! need your help (eg6ajk)
couldn't have said it better.
Old Mar 3, 2003 | 03:20 AM
kenji's Avatar
25 Year Member
Default Re: Kenji !!! need your help (poison)
Thanks Adrian
-kenji
Old Mar 3, 2003 | 06:07 AM
Jason kiDD's Avatar
Default Re: Kenji !!! need your help (kenji)
kenji maybe you can help me as well. I have a p13AT JDM ECU that I use with my engine and I recently got a Spoon chip for it. However till this day the thing doesnt seem to want to work at all and gives the CEL light always on error on the ECU side. Now I had a so-called proffesional install the socket but still to no avail. I also had someone else from the board look at it but he has had the ECU for about a month now without any progess. I was wondering if there is anything you can do since this is your field of expertise..
Email me @ jdjoseph2000@hotmail.com, since your IM is turned off.
Old Mar 3, 2003 | 05:08 PM
d styles's Avatar
Default Re: Kenji !!! need your help\youngster\
kenji,I just install a b16a sir non obo engine,and it don't have any fire.What can I do to fix it.One more thing can I use 2000 gsr injectors.
Old Mar 3, 2003 | 05:12 PM
d styles's Avatar
Default Re: Kenji !!! need your help\youngster\ (youngster)
Old Mar 3, 2003 | 05:16 PM
VTECVillain's Avatar
I'm not Kenji but here goes: If you are using the OBD0 ECU (PR3 or PW0) you SHOULD use OBD0 injectors which could be from the ODB0 B16A, 88-91 Civic/CRX Si or HF or the 90-91 Integra along with an injector resustor box. Some people use OBDI and OBDII injectors with the OBD0 ECU without the use of an injector box and it works, but to be on the safe side just keep it OBD0.
Old Mar 4, 2003 | 09:23 AM
d styles's Avatar
Default Re: Kenji !!! need your help\youngster\ (VTECVillain)
thank's for the reply.but it still got no fire,only for one second and it stop.you think I did the wiring wrong?
CRX_RR
Feb 21, 2008 04:20 PM
crazyguy
Sep 8, 2007 01:15 AM
UncivilB18C
Apr 10, 2006 05:21 PM
thehondaguru
Nov 26, 2003 06:55 AM
quick92hatch
Aug 3, 2003 10:27 PM
