Do i need this mount?
Old Feb 19, 2003 | 05:55 PM
FormulaEJ8's Avatar
Default Do i need this mount?
Do i need my front lower pass. mount that connects to the tranny. I know it cant hurt to not use it but i still cant figure out how to hook it up. I bought an ex mount and the si and neither will fit. It seems the stud is too short when using the ex mount and then the si wont fit to the chassis because it has a full top peice. Hope someone can help.
Old Feb 19, 2003 | 05:57 PM
Irishweird00's Avatar
Banned
Default Re: Do i need this mount? (9d6ek)
what motor is it
Old Feb 19, 2003 | 06:00 PM
FormulaEJ8's Avatar
Default Re: Do i need this mount? (Irishweird00)
b16a2, not too torqey so i figure the mounts will just ware faster if anything at all
Old Feb 19, 2003 | 06:09 PM
Banned
if its the Ek chassie, then The only mount you need is the rear upper mount. From the Si.... All the other mounts are bolt in. I'm not sure about the eg civics or others. but go here http://tech.hybridgarage.com/tech/index.html great site for tech on swapping.
Old Feb 20, 2003 | 05:03 AM
VTECVillain's Avatar
If you are installing this into a 92-95 Civic then you need the 94-01 Integra lower tranny bracket and reuse your stock rubber end mount.
Brandon H.
Aug 14, 2011 06:57 PM
HondaEF
Nov 20, 2005 10:22 PM
strictlyimport
Jun 19, 2005 06:18 AM
Adam.
Nov 1, 2004 02:00 PM
blackboosted2
Mar 7, 2004 09:11 PM
