Which coolant reservoir tank for my Eg / GSR Hybrid?
I know I'm getting a new coolant reservoir tank since my Cx one is black as hell on the inside from the previous pig who owned the car. I am curious if they (Cx, Del Sol Vtec, GSR) are all the same capacity and mount the same to the car?
I am thinking about getting the Del Sol's reservoir tank since I will be running a Del Sol dual core radiator.
Any input on this would be great, thanks!
Re: Which coolant reservoir tank for my Eg / GSR Hybrid? (fowler)
Stick with what you have. I don't think there would be any advantage to get a bigger/smaller resevoir tank.
1 Post
Re: Which coolant reservoir tank for my Eg / GSR Hybrid? (Hybrid93Hatch)
I meant stick with the proper one for your chassis.
Like I said, you won't notice a difference. I'm not even sure it will make a difference.
I bet you the gsr, the del sol and the stock cx resevoir hold the same capacity.
Is it bad enough you can't clean it out? Mine was bad but I just cleaned it out and painted the outside flat black and it looks and works fine.
B_1_8_hatch
15
07-22-2003 09:27 PM
elmalouno
06-04-2003 12:05 PM
