the PERFECT close fit alternator belt for crvtec
I dunno if anyone cares, but using a CRV crankpully with a 32" 4 rib belt, it fits so perfect, its scary. For me, I needed a belt that just barely fit, to get it to fit, you need to take the top bolt off, this will allow u to slide it tward the engine block just a little more. That little bit allows the belt to slip on, then just pull the alternator away, and then adjust the belt as normal. A very close fit, ill post pics up later.
This is perfect for anyone like me that has crvtec in a crx.
part # 320K4 from pepboys
Re: the PERFECT close fit alternator belt for crvtec (irev210)
that pulley makes for a very tight fit, it might the the radious arm! on mine, i used a b16 crank pulley, and the 88 crx alternator belt. it fits perfectly!
Re: the PERFECT close fit alternator belt for crvtec (smokey2.0)
yah ill find out if it fits
if not, ill just have to get a b16 crank pully, no biggy
it didnt hit my radius rod
though if i was slamed it prolly would
