Will disconnected KS cause CEL?
Old Feb 19, 2003 | 07:51 PM
43MA's Avatar
Default Will disconnected KS cause CEL?
if knock is not wired in will it cause the ecu to default into full retarded timing?
Old Feb 19, 2003 | 08:06 PM
poison's Avatar
Default Re: Will disconnected KS cause CEL? (Steady)
yes, also known as safe mode. you will need to wire up knock sensor.
Old Feb 20, 2003 | 01:40 AM
NirSpec1's Avatar
yes unless you have a chipped p28 then it won't
Old Feb 20, 2003 | 04:02 AM
VTECVillain's Avatar
If your ECU has the knock sensor feature and you don't wire it up or disconnect it then it will throw the CEL and run in safe mode.
Old Feb 20, 2003 | 02:07 PM
43MA's Avatar
i guess that would explain why its slower then a single cam
time to go wire in knock sensor
Old Feb 20, 2003 | 04:32 PM
Katman's Avatar
heh yeah, the stock honda KS is wack, it hellified kicks back timing when it detects any sort of knock, even the smallest of knockage.
jdmdseries
Nov 16, 2007 03:46 PM
s_vares
Sep 3, 2006 02:54 PM
Hartattack
Dec 19, 2005 05:46 PM
PhatHardy
Apr 3, 2003 06:31 PM
