answer needed right away!!! timing belt....
Re: answer needed right away!!! timing belt.... (b16ahybrid)
I am also haveing trouble putting on my timing belt it is too short. I am using a gsr timing belt for my ls/vtec setup I was using the vtec oil pump but with that on there, there is no way I will be able to put the belt on. any ideas on getting it on?
confused
mike
confused
mike
Re: answer needed right away!!! timing belt.... (infamousLSVTEC)
what water pump are you using?
i used gsr oil pump and gsr water pump
with gsr timming belt part number is 14400-p72-014
Re: answer needed right away!!! timing belt.... (turbodav)
ok so schucks can lick a nut... they gave me belt part no. 95227 when I needed 95227 they could not even find what belt I had... with the gsr belt it went on with no problems.
thanks for all the info anyways
mike
mike
