need some help rewireing my 88 crx si harness for a b18c1
I am about to start my swap. I have a OBD2 b18c1 and I am droping it in my my 88 crx si.
I was told to just re wire my sock crx harness. how do I do this, do I just cut the plugs off and re wire them with the OBD2 plugs? I do have the OBD0 to OBD1 harness for my ECU so that takes car of the inside I will be running OBD1 electronics, but what about the engine?
I was told it is easy to modify the stock harness, but Im not sure what to do. any tech write ups, or web paages that can help me?
I have done other swaps, but they were always pretty much plug and play.
thanks
[Modified by DOHCarp, 5:07 PM 2/22/2003]
thanks
Re: need some help rewireing my 88 crx si harness for a b18c1 (DOHCarp)
easiest thing to do is get obd1 plus and splice them onto your obd0. Just grab the diagrams from both the crx and vtec obd1 ecu. If u need the ecu plugs i have some. 5 bucks also u can repin the ecu, thats a little harder but u dont have to cut up your stock wires.
Re: need some help rewireing my 88 crx si harness for a b18c1 (xsolidcellx)
I have the OBD0>OBD1 harness for my ecu so other then that i am just maching up the wires almost color for color right?
thanks
thanks
jarhead90crx
12
08-05-2011 07:06 AM
nitroracer
09-09-2006 07:50 PM
JDMBOLONI
16
07-22-2002 07:12 AM
