Swapping B17A1 Into 92 VX. Need help with converting to a 4-wire 02 sensor.
I have all the information for the wiring except on what ECU pinouts to use for converting the vx's wideband 02 sensor to the B17A1 style 4-wire sensor. I have searched and searched but came up empty handed. Any help would be GREATLY appreciated.
Re: Swapping B17A1 Into 92 VX. Need help with converting to a 4-wire 02 sensor. (92tealvx)
i have the pin locations. im me and i get them for you when i get home(im on my friends comp.)
old post of mine
okie, i found the setup, the yel/blk wire needs to get routed all the way to the ecu, at least i found it easier to do it that way, then it gets t'd into the yel/blk on A and the yel/blk on B at the ecu. The other 3 wires you can use ones from the VX harnes, you'll have to make your own plug setup though, or just hardwire them. I bought a 4 wire waterproof wiring harness from pepboys, both the male and female then rewired both sides at the old plug area.
Okie, for 4 wire the wires are this:
Grn/Wht 2
Wht 1
Orn/Blk
Yel/Blk
for 5 wire they are:
grn/wht 2
wht
wht/blu 2
orn
orn/blu 2
yel/blk
blk 1
Okie for the the other wires, take the 5wire yel/blk and that goes to the 4wire orn/blk, grn/wht 2 is the same on both 5wire and 4wire, and orn/blu 2 is the wht1 for the 4wire o2. IM me if you need any more info.
btw. the above colors are directly from the helms, some of those cables are routed inside the cable plug so you dont think, gee thats more than 5wires...
Grn/Wht 2
Wht 1
Orn/Blk
Yel/Blk
grn/wht 2
wht
wht/blu 2
orn
orn/blu 2
yel/blk
blk 1
hondaman92civic
05-14-2010 03:09 PM
dremmel
02-17-2004 08:24 PM
AdamITR
05-14-2003 05:44 PM
