need help?
Old Feb 24, 2003 | 10:39 PM
kai-ten01's Avatar
Default need help?
i have a gsr swap into a crx. and it's wired up to obd0. the problem i'm getting is that it wou't let me go above 3200 rmp. can someone please help and let me know what i can do or atleast let me know what is the problem? i already replace the distributor to a b16a1 and it's still flashing code 4 on the ecu. we think it's the tps but on the code it says it's the ckp,tds. please help and let me what is wrong... thanks... you can also email me your responds at kai_ten01@yahoo.com thanks...
Old Feb 25, 2003 | 04:38 AM
VTECVillain's Avatar
Default Re: need help? (kai-ten01)
Did you originally have a DX and changed it to MPFI using the stock harness? Code 4 is the Crankshaft Position Sensor, the one that needs to be rewired when you change a DPFI motor to MPFI.
Old Feb 25, 2003 | 10:41 AM
kai-ten01's Avatar
Default Re: need help? (VTECVillain)
i had a crx dx and change the wiring to zc. that's what i did to my ride.
Old Feb 25, 2003 | 11:54 AM
Check and double check your DPFI to MPFI wiring.
Old Feb 25, 2003 | 03:17 PM
kai-ten01's Avatar
thanks imma go check it....
Old Feb 25, 2003 | 03:18 PM
kai-ten01's Avatar
hey can you email me at kai_ten01@yahoo.com and kinda explain more on what is the dpfi and the mpfi? please thanks..
88efsedanlx
Dec 10, 2011 05:40 PM
Bright Eyes
Jun 3, 2005 05:52 PM
Schaz
May 18, 2005 10:53 PM
enigma94
Jun 15, 2004 07:12 PM
HybriDNA
Apr 10, 2003 07:43 AM
