Problem- CRVTEC woes.... strange engine noise...
Okay, i finished my crvtec swap into my 89 CRX HF, I got blown90hatch's obd0-obd1 harness, so im running obd1, i had a problem with a bad injector resistor box, so i just went with obd1 saturated injectors... so today was the first day i was really able to drive the car. I notice that once the engine warmed up, a loud screech came from the engine. I dont know what it is. When i give the car gas, the sound goes away, once i left off the gas, it comes back. Its fairly loud, and im afraid to drive the car because I dont want a main bearing going out on me or something.
If anyone can help, Id really appreciate.
Re: Problem- CRVTEC woes.... strange engine noise... (irev210)
okay here is an update
took off A/C belt
took off alt belt
took off upper plastic cover
pressed in clutch
when the engine is turned off, i can see the timing belt stop, but for a second after the belt stops, the stupid whine is still there... its comming from the motor, the whine stops about a second or 2 after the motor STOPS moving
im very confused
someone please help!
Sorry if it doesnt make much sense, but im very tired
took off A/C belt
took off alt belt
pressed in clutch
im very confused
Re: Problem- CRVTEC woes.... strange engine noise... (There is no sp00n!)
No, he found it...https://honda-tech.com/zerothread?id=422616.
myhondatechacct
07-21-2011 08:57 PM
freefall365
10-27-2010 09:19 PM
