which air intake for h22 on an eg
Old Feb 18, 2003 | 08:50 PM
Chiclets's Avatar
Default which air intake for h22 on an eg
which air intake shoul I buy for my h22 on my eg I want It to fit and and perform like any other intake on a stock engine would
Old Feb 18, 2003 | 09:02 PM
fastwanabe's Avatar
Default Re: which air intake for h22 on an eg (bluedemon)
99 si or ITR, as far as stock intake I have no clue.
Old Feb 18, 2003 | 09:06 PM
Chiclets's Avatar
Default Re: which air intake for h22 on an eg (fastwanabe)
i'm more concerned about it fintting on there rigth is the 99 si the best fit?
Old Feb 18, 2003 | 09:24 PM
k_spek's Avatar
I know the 99-00 si cai fits perfect. My itr one fits fine too. Where it bolts to the frame rail though i made a 2" spacer and used a long screw because the filter sat too low to the ground for my tastes with it bolted to the frame rail with the stock rubber spacer.
[Modified by laugHin22CX, 6:26 AM 2/19/2003]
Old Feb 18, 2003 | 10:31 PM
ranta18's Avatar
Default Re: which air intake for h22 on an eg (laugHin22CX)
I have a 92-96 Prelude VTEC AEM cold air intake with the bypass valve in it and it fits perfect. Goes right through the hold and the bottom of the filter is right at the bottom of the front bumper. I think the Civic Si one is smaller diameter. The one I have is 3"
Old Feb 19, 2003 | 12:14 PM
k_spek's Avatar
Default Re: which air intake for h22 on an eg (ranta18)
The prelude on is 3"? I didn't know that. That's cool.
Old Feb 19, 2003 | 01:20 PM
heiyu's Avatar
make your own its easy, and it cost less
Old Feb 19, 2003 | 02:10 PM
Newman's Avatar
New User
Yeah, but the Prelude intake arm is in the shape like an "M" to clear the battery in a Prelude. If you use a 99 Civic Si intake or a 92-95 Civic intake (3" for aftermarket, or the stock one), it fits perfectly and bolts into the same locations on the chassis for the support bracket. The ITR intake (aftermarket) is slightly longer and needs to be trimmed about 1-2 inches (well, at least on this car we did it had to) but otherwise fit fine.
Old Feb 19, 2003 | 04:37 PM
redlineh22a's Avatar
Default Re: which air intake for h22 on an eg (Newman)
Will the stock intake EG fit on the prelude throttle body?
Old Feb 19, 2003 | 07:31 PM
poison's Avatar
Default Re: which air intake for h22 on an eg (redlineh22a)
yes it will. as well as the aem cai.
Old Feb 19, 2003 | 07:34 PM
BeerBaron105's Avatar
Default Re: which air intake for h22 on an eg (poison)
hype R is 3 inch and fits good
z06eateR
May 16, 2008 11:15 PM
blackdelslo
Aug 14, 2004 08:45 PM
AkEuro_R
May 2, 2004 01:41 PM
Downey
Mar 22, 2004 08:18 AM
C M S
Nov 19, 2003 10:03 PM
