Quick swap question from an EK newbie
Old 02-17-2003, 10:37 AM
Phaze2 Mike's Avatar
Default Quick swap question from an EK newbie
Well guys (and gals), usually i stick with my 4th/5th gens, but i was asked to do a obd2 LS motor into a 96 civic. Aside from the normal, engine/tranny/harness/ecu/axels/shift linkage, anything else needed? WIll the mounts work, or are certien different mounts (99-00 b16?) needed? Also, anything else im completly overlooking, thanks.
Old 02-17-2003, 11:44 AM
iwhichisme's Avatar
Default Re: Quick swap question from an EK newbie (Nextekhatch)
THe same as any other b-series swap, but w/o all the extra wiring.
Old 02-17-2003, 12:55 PM
Default Re: Quick swap question from an EK newbie (iwhichisme)
so b-series is a direct bolt in into the 96-00 chassis?
Old 02-17-2003, 01:05 PM
fkncivic's Avatar
you will need mounts from a 99-00 civic si
Old 02-17-2003, 01:19 PM
fowler!'s Avatar
Default Re: Quick swap question from an EK newbie (fkncivic)
More specifically..
The mount on the motor between the timing belt
The rear tranny mount
AC mount.
xft
10-11-2008 07:45 PM
SeVeNisOnE
18
05-21-2008 03:02 PM
99TurboBlue
07-09-2007 05:07 AM
SyDuck
01-28-2005 06:59 PM
Quick Reply: Quick swap question from an EK newbie
