93 ex powersteering pump....work on b16 block?
tried searching for this and turned up like no results...but i was wondering if the powersteering stuff from a 93 ex d16z6 will maybe work with the b16 block? if not which would be the best to use...and can the stock lines and all on the car work still?
Re: 93 ex powersteering pump....work on b16 block? (93civEJ1)
i don't think d-series and b-series pumps are interchangeable. use a b16a pump and see if your stock lines will bolt up to it, they should. my ITR swap and pump worked just fine with the stock lines in my EK.
[Modified by YumVTEC, 7:13 PM 2/19/2003]
Re: 93 ex powersteering pump....work on b16 block? (YumVTEC)
kool deal.......thanks..if it doesnt come with the powersteering then i guess that is something that i will be looking to get as well as bracket for the a/c, hopefully the stock a/c compressor will work on a b-series bracket?
EGinNY
06-17-2004 06:31 PM
93civEJ1
02-19-2003 10:14 AM
