99-00 Civic Si AC bracket same as Del Sol P54?
Old 02-17-2003, 01:19 AM
Sushi Buffet Champion
GapxGuy's Avatar
Default 99-00 Civic Si AC bracket same as Del Sol P54?
Is the 99-00 a/c bracket the same as the delsol's P54? Does anyone know if the 99 Si a/c bracket have "p54" stamped on it? I ordered the 2000 a/c bracket and the part number turned out to be 38930-P30-000 and now I'm worried.
Old 02-17-2003, 10:10 AM
Trey's Avatar
Default Re: 99-00 Civic Si AC bracket same as Del Sol P54? (GapxGuy)
I ordered a 99-00 Si ac bracket and got the P54 one. If you call the dealer parts guy he'll guote you the P30 one.
They both work, the real issue is the Civic coompressor. There are different ones and some bolt to the P54, others bolt to the P30.
Just try it. If the P30 doesn't work, get the del Sol one, it's listed as the P54 at the dealer now.
Old 02-17-2003, 06:18 PM
rathead's Avatar
if your doing a b swap into a 92-00 civic hatch. you need the del sol braket. the 99-00 civic braket will not work with hatch ac compressor
end of story
Old 02-19-2003, 11:35 AM
93civEJ1's Avatar
Default Re: 99-00 Civic Si AC bracket same as Del Sol P54? (rathead-ek)
what ac brackets will work in a civic with the stock d16 ac compressor on a b16 block???
Old 02-20-2003, 04:20 PM
rathead's Avatar
Default Re: 99-00 Civic Si AC bracket same as Del Sol P54? (93civEJ1)
a del sol braket(b-16 del sol)only
Old 02-20-2003, 04:40 PM
ArinX's Avatar
so the aluminum jdm itr one wont work??
AXiONMOTORS
02-21-2009 05:15 AM
r0cket247
03-28-2004 02:46 PM
GapxGuy
02-17-2003 01:01 PM
allmtr
07-29-2002 01:51 PM
Quick Reply: 99-00 Civic Si AC bracket same as Del Sol P54?
