92 LS swap into 88 CRX!!??
what do i need to make this happen??
i have a full 92 integra swap from my wrecked 92 Gs...everything i need...what will i need to make this work in a Rex???
thanks guys...and if anyone has any parts to make this work that i don't have...let me know....!!!
Re: 92 LS swap into 88 CRX!!?? (VTEC93hatch)
http://www.hasport.com has the info your looking for.
They have a full run down of all the parts needed.
Well then all you need is some motor mounts.... All you have to do is the wiring which is a sinch. You will have to either get a aftermarket shift linkage or just cut the stock integra shift linkage in the middle to make it a little bit shorter so it will fit on the crx. Thats all you have to do since you got the whole integra to part from. GoodLuck.
92integra-R
10-31-2008 03:19 PM
brian estrada
10-27-2003 12:42 PM
