CEL code #23 ?
Old Feb 20, 2003 | 07:57 AM
hybrider's Avatar
Default CEL code #23 ?
it was hessitating out of nowhere yesterday and i had to struggle for it to turn on, and just checked the CEL today and got 23, anyone know what it is?
Old Feb 20, 2003 | 07:59 AM
hybrider's Avatar
Default Re: CEL code #23 ? (hybrider93)
never mind, found it......but i doubt this is the problem, doesnt make any sense...
23 Knock sensor circuit Open or short in Knock sensor circuit, defective Knock sensor circuit
Old Feb 20, 2003 | 08:08 AM
Newman's Avatar
New User
Two things to check.... make sure your knocksensor itself it still good, but more common, check the wire(s) leading from the knock sensor to the ECU and make sure that it's not shorting out somewhere. If it's fine, then it's still good to rerun a 14-18 AWG wire directly from the knock sensor, directly to the ECU so there's no breaks in the line. Usually this clears up the problem unless your knock sensor itself is bad (which I've also seen).
Old Feb 21, 2003 | 12:37 PM
hybrider's Avatar
Default Re: CEL code #23 ? (Newman)
turns out i was throwing code #3, wtf was i thinking?
anyhoos changed MapSensor, and still throwin the code....grrrr, time to check for a short somewhere
thx newman
Old Feb 21, 2003 | 09:12 PM
baonest1's Avatar
you reset the ecu after you changed it..... disconnect the negative fer couple min.
Old Feb 21, 2003 | 09:31 PM
hybrider's Avatar
Default Re: CEL code #23 ? (baonest)
ya did that
Old Feb 21, 2003 | 09:50 PM
baonest1's Avatar
ya did that
hmmm...
Apex1972
Feb 12, 2008 09:55 AM
oranginal
Jul 6, 2006 02:17 PM
civisaurusrex
Jul 24, 2003 05:48 AM
shonnys92si
Feb 17, 2003 08:27 AM
Thagreybomber
Sep 9, 2002 07:17 AM
