I did a search........B18c1 obd2a into Civic DX 1999 obd2b
like i said i did a search and came up with nothing ......I know that i can use a civic ex 1999 engine warness but I didnt found anybody that wrote a complete how-to....anybody has a how to or a website that tells a complete how to......thanks for the info
Re: I did a search........B18c1 obd2a into Civic DX 1999 obd2b (intrex)
putting a gsr into your civic is simple. just make sure the motor is obd2 96 and up. everything should plug up. except adding a couple of wires for knock, vtec, oil, and secondary butterfly, i think. u will need a 96 and up ecu p72 axles, shift linkage all b-series and 99 si back bracket
Re: I did a search........B18c1 obd2a into Civic DX 1999 obd2b (chinoty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chinoty »</TD></TR><TR><TD CLASS="quote">putting a gsr into your civic is simple. just make sure the motor is obd2 96 and up. everything should plug up. except adding a couple of wires for knock, vtec, oil, and secondary butterfly, i think. u will need a 96 and up ecu p72 axles, shift linkage all b-series and 99 si back bracket</TD></TR></TABLE>
if u use ur OBD2B harness you will need to move some pins around, cause the ecu plugs are not all the same, between OBD2A and OBD2B
Re: I did a search........B18c1 obd2a into Civic DX 1999 obd2b (AL ASPIRATED)
I need to know the mounts also. I know I'll need the SI drivers side mount and the AC mount but what about the mount next to the tranny?
Re: I did a search........B18c1 obd2a into Civic DX 1999 obd2b (thebonniesong)
You can reuse the one off of you d-series motor. It will bolt right up to the tranny.
Modified by lilkong at 5:07 AM 4/15/2004
Re: I did a search........B18c1 obd2a into Civic DX 1999 obd2b (lilkong)
Can any one help me with my swap?
I am doing the same swap but it is going in to a 97 Civic DX which is "obd2a". I am using a 00 Si engine harness (obd2b) with a conversion harness from obd2b to obd1. Ok this the problem. On the engine harness it only has the B & C plug for the ECU. Correct me if I'm wrong, but I would need the A plug for the swap to work right?
Diagram in link: http://www.turbod16.com/viewtopic.php?t=3572
Modified by lilkong at 7:29 PM 4/22/2004
JDM99DC2
04-11-2005 02:08 PM
