just did an 2000 LS swap into my 1999 ex... need ECU HELP ASAP PLEASE!!!
Hey guys... we just swapped a 00 LS motor & tranny into my 99 ex....
we used the Ex Auto harness.....
when we plugged it up to the LS ecu p75 (i think) ...... the car will not start
The car is running on the EX AUTO ECU right now
PROBLEMS:
1. Idels at 1700 or so....
2. I need to use the LS ecu
Can someone help me out w/ info..... I heard u have to rewire the pins 15/16?
PLEASE HELP ME... I want to Turbo my car soon & cant afford it to run like this for time being ....
Thanks in advance
PROBLEMS:
Thanks in advance
Re: (99SlammedCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99SlammedCivic »</TD></TR><TR><TD CLASS="quote">its a 5spd motor...
come on guys... help me</TD></TR></TABLE>
People are tying to help you, just calm your *** down or no one is going to want to help you. What does the car do when you try to run it off the LS ecu? Will it crank? Does it toss any codes? Have you even checked for codes?
Re: (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">
People are tying to help you, just calm your *** down or no one is going to want to help you. What does the car do when you try to run it off the LS ecu? Will it crank? Does it toss any codes? Have you even checked for codes?</TD></TR></TABLE>
damn man... thats unnecissary... (in bold)
Anyways.... the car will not turn on w/ the LS ecu... it has spark & fuel, just will not turn on....
Maybe not necessary to you, but you sounded pushy in your response. Perhaps this ECU has an imobolizer in it? If its a 2000k ECU, then I am pretty sure this is your problem. I know the GSR's had them in that year and I am pretty sure the LS did as well.
Re: just did an 2000 LS swap into my 1999 ex... need ECU HELP ASAP PLEASE!!! (99SlammedCivic)
If your Civic originally had an auto Ex in it, then it also had a 3-wire IACV. The LS motor uses a 2-wire IACV. Did you do the IACV connector fix and re-pin at the ECU?
Do you have a Helms?
Re: (*******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ******* »</TD></TR><TR><TD CLASS="quote">might be easier just getting a obd1 jumper harness and an obd1 LS ecu.</TD></TR></TABLE>
thats what might end up happening
mc_civic213
04-11-2008 06:22 AM
sihatch19
05-21-2004 10:52 PM
