Question about B16 and B18
Old Mar 22, 2004 | 07:56 PM
Jahtoot84's Avatar
Default Question about B16 and B18
This may sound kind of dumb. But I wanted to ask you H-T members before I go about doing something. I have searched and found sketchy answers.
Okay here is my situation.
I have a B16 complete swap in my EG, but then the B16 motor blew. After saving up for a B18C long block. Could I just swap this long block directly in.. using the B16 tranny, and the other parts I had on my B16 such as Findanza Flywheel, ACT stage 1 organic clutch. Remember I will just be taking out the B16 and placing the b18C motor in place of it, not changing anything else, including the ECU... Will this work just fine? or will I have to do something else to get the B18C running healthy?
Any comments welcome.. Good or bad (flame suite on hehe)
Thx all..
Modified by Jahtoot84 at 7:09 AM 3/23/2004
Old Mar 23, 2004 | 04:39 AM
VTECVillain's Avatar
Default Re: Question about B16 and B18 (Jahtoot84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jahtoot84 &raquo;</TD></TR><TR><TD CLASS="quote">I have a B16 complete swap in my EG, but then the B16 motor blew. After saving up for a B18C long block. Could I just swap this long block directly in.. using the B16 tranny, and the other parts I had on my B16 such as Findanza Flywheel, ACT stage 1 organic clutch.</TD></TR></TABLE>
Yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Remember I will just be taking out the B16 and placing the b18C motor in place of it, not changing anything else, including the ECU... Will this work just fine? or will I have to do something else to get the B18C running healthy?</TD></TR></TABLE>
If it's a GSR spec B18C then you will need to change to a Skunk2 or similar single runner manifold if you continue using the B16 ECU, everything else you have will work. Your other choice would be to get a P72 GSR ECU, both options would be near the same cost but I personally think the manifold would be a better choice. Now if it's an ITR spec B18C then you will not need to change the manifold/ECU.
Old Mar 23, 2004 | 10:09 AM
Jahtoot84's Avatar
Default Re: Question about B16 and B18 (VTECVillain)
k man thx for the info.. I really appreciate it.. Think ima go the manifold route.. thx again
ToTriggerHappy
Oct 4, 2010 07:50 AM
b16wanter
Jun 17, 2004 04:10 PM
boostincoupe
Jun 23, 2003 11:05 PM
EKhatch
42
Dec 29, 2002 05:20 PM
