IACV power wire
Old Mar 22, 2004 | 12:42 PM
SAVIOVEGA's Avatar
Default IACV power wire
On EG harness, the IAC plug has 2 wires. The Blue/yellow wire goes to the ECU and the Yellow/black gets 12V. My question is which is the top wire on the plug?
Old Mar 22, 2004 | 02:22 PM
poison's Avatar
Default Re: IACV power wire (SAVIOVEGA)
The clip should only go one way. The Yel/Blk wire is the power going to A25 and the other is ECU signal.
I believe the Blue/Yel is the top, if that didn't work, then switch the wires. -- I'm assuming you pulled the pins from the plug or something.
Old Mar 22, 2004 | 03:04 PM
SAVIOVEGA's Avatar
Default Re: IACV power wire (poison)
Yeah I pulled the pins out and forgot where they went
I'm trying to get rid of this code 14 on my H22 swap. I'll figure it out.
Thanks
Old Sep 1, 2004 | 09:04 AM
IVI's Avatar
IVI
did you figure out whats supposed to be at top?
im having the same problem.
which wire goes where on the ecu so i can check for continuity?
Old Sep 1, 2004 | 02:00 PM
Turbogixxer's Avatar
Default Re: IACV power wire (IVI)
Old Sep 1, 2004 | 02:37 PM
IVI's Avatar
IVI
Default Re: IACV power wire (turbogixxer)
thanks turbogixxer.
1 more thing, what is junction conn c125? where is that located ?
jdmsir4dr
Apr 25, 2013 08:33 PM
dstah
Engine Management and Tuning
May 2, 2009 10:13 PM
PhrequenC
Aug 5, 2008 11:15 AM
97hatchb16
Sep 4, 2006 08:42 PM
Morhpeous
May 30, 2004 05:33 PM
