Mount kit for a 90-93 Teg..?
Is there a cable to hydraulic mount kit available for a 90-93 Acura Integra LS? I plan to swap in a 94 B18c w/ a hydraulic transmission. Although, I've seen mount kits made by Hasport which converts 88-91 Civics to accept hydraulic type transmissions, is there a similar kit made for 90-93 Integras? Or, can I use the same Civic kit?
Thanks, any info would be greatly appreciated....
Re: Mount kit for a 90-93 Teg..? (DarkSol97)
civic kit will work for using the hydro tranny, then use all your 90-93 teg mounts on it and you'll be set (actually I don't think you use the front mount).
Re: Mount kit for a 90-93 Teg..? (91IntegGS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91IntegGS »</TD></TR><TR><TD CLASS="quote">http://www.g2ic.com/forums/showthread.php?t=88667</TD></TR></TABLE>
Thanks for the link
Thanks for the link
Jared
11-09-2001 05:59 PM
