0bd 0 to 0bd 1 conversion hasport, dx to mpfi d16z6, 02 sensor code HELP
Ok I have a 91 crx dx. converted over to MPFI. Then I have OBD1 on it and the only code it is throwing is the O2 code. For some reason I can't figure out the o2 wiring. They say I have to run the wires to D14 and D22. But hwere is that at. I only have three plugs. A B and C. Wheres D?
If I could find that out that would be great. Sorry about all the posts. I was pissed last night. I will delete some of them.
Ok i have a new question. Where is sam hell is D14. I am really pissed off right now and I need some freaking help. Thanks. Has anyone switched there car from obd0 to obd1 with the hasport harness. For some reason i cant get the o2 code to go away. Heres what I have. DX crx to MPFI. D16z6 engine. hasport shorty harness for the obd0 to obd1 conversion. I have directly wired the o2 sensor up to the ecu but that didn't work. Does the o2 have to read the temp sensor, tps, and the coolent temp. I have the heater code gone so that can't be it. could someone tell me how to wire this would be good.
thanks guys. its for a friend that wants to cry, his car has been throwing codes for years.
Re: 0bd 0 to 0bd 1 conversion hasport, dx to mpfi d16z6, 02 sensor code HELP (stolencrx)
If you converted over to obd1 did you use a harness converter? If so you need a 4 wire o2 to work with your obd1 ecu. Be more specific about your setup and I'm sure we can help.
nickel168
10-27-2007 01:22 PM
vegaskurt
06-30-2006 10:55 AM
