working air conditioner & ps with H22 in a civic.........................................?
Guest
Posts: n/a
Ivplan on doing a h22 swap into my 92civic. I will be using this as a daily driver and want to loose my Power steering and Air conditioner. My question is has anyone in here intergrated this into their setup? If so what modifications did you have to do if any....
Re: working air conditioner & ps with H22 in a civic.........................................? (MUTA
Yes people are using their ac/ power steering with special brackets. Check out jdmsh!ts website , but to be honest I think it's not worth it down the road. I recently put a Imagine engineering header in and clearance was a bit tight , but look into it.
thats right..
yes, it can be done.. takes a lil custom work. but not to hard.
hcp makes the condeser bracket. I was planning on keeping both but when your actually doing the swap you will see how much easier it is with all the stuff out of the way.
Yes... you can retain the AC by bolting up the stock Civic SOHC Sanden A/C compressor to the HCP H22 A/C bracket (that we carry). You can also retain the P/S by using the Prelude power steering pump & bracket, and welding or flaring the high pressure lines to the Civic lines. Depending on what chassis you have the H22 in (EG Civic, EG Del Sol, EK Civic, DC Integra), you can use the 92-96 Prelude P/S parts as it'll clear the hood. But on the EG Civics, the hoodline is closer so you need to use the smaller 97+ Prelude H22 P/S pump & bracket.
80 dolla crx hf
05-22-2009 07:02 AM
Tyson Ballou
09-23-2002 04:44 PM
4g4me
05-01-2002 05:57 PM
