Why can't I use the driver's side mount from my 95 EX for a B18B swap?
The mount on the Integra appears to be exactly the same as the Civic so why do some people say that it can't be used? I have the helms manual for both a 95 Integra and 95 Civic and the bolts and mounting holes are the same for both as well. What is the reason?
Re: Why can't I use the driver's side mount from my 95 EX for a B18B swap? (araychel)
you can.
both are 3 bolt right?
trust yourself most of the time.
I have used it for 2 successful swaps.
I think people dont mention it becuse the mount in question is different on some D series motors... my 1993 CX is different from a 1995 Si that I did a swap on.
But yes, the 1995 Si mount was identical to my 1994 GSR mount
Re: (Shaun)
no, sohc bolts to the motor with 2 bolts, dohc bolts to the motor with 3.
I am referring to the bracket that actually bolts to the motor under the timing cover.
