OVERHEAT at higher rpm! why?
what signal could that cause? i need to know about this asap.
by the way i did change thromast and radiator but still overheat?
could it be water pump or headgasket?
by the way i have 88 honda crx with jdm b16a
thanks
thanks
Re: OVERHEAT at higher rpm! why? (dutchman5)
could be your water pump. when i drove on the freeway at 80mph which is about 4400 rpm my temp gauge used to go up almost to the red. when i changed the water pump never had that problem again.
Re: OVERHEAT at higher rpm! why? (ACRProject)
yeah my fan is working and i ll try to replace the water pump hopefully it ll solve the problem.
thanks
thanks
what kinda car and radiator are you using?
does it on the highway or just whem your running it up in high rpms?
Re: OVERHEAT at higher rpm! why? (saleensolution)
at the first place i was using the C&R radiator and it start overheat so i reaplce with the dual del sol radiaor. it s work great.
On the highway it was fine but when i was racing with somebody and it s start to get overheat when i m using the higher rpm.
gstrudler
07-28-2009 09:22 PM
