Help Needed! Car wont pass BAR inspection!
sold my friend my car(1996 civic EX) about a year ago, has a 98-99 LS swap in it, i never got it BAR'd. He went to get it BAR'd today and they told him the wrong ECU was in the car. When i bought the swap from a wrecking yard they gave me the ecu that was to be for that engine. It turns out that the ecu says on it 96 LS not 98 or 99 (written in pen from the wrecking yard). I always thought that the ecus were the same from 96-99 and different in 00-01? What should i have my friend do? As of now they are not passing the car because of this everything else checked out fine. TIA
Re: Help Needed! Car wont pass BAR inspection! (infinkc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infinkc »</TD></TR><TR><TD CLASS="quote"> sold my friend my car(1996 civic EX) about a year ago, has a 98-99 LS swap in it, i never got it BAR'd. He went to get it BAR'd today and they told him the wrong ECU was in the car. When i bought the swap from a wrecking yard they gave me the ecu that was to be for that engine. It turns out that the ecu says on it 96 LS not 98 or 99 (written in pen from the wrecking yard). I always thought that the ecus were the same from 96-99 and different in 00-01? What should i have my friend do? As of now they are not passing the car because of this everything else checked out fine. TIA</TD></TR></TABLE>
The only thing I can think of is you are using a federal emissions ECU and are in need of a California emissions ecu. There is a difference, you know?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infinkc »</TD></TR><TR><TD CLASS="quote">ecu was from a CA car.</TD></TR></TABLE>
Gimme the numer off the ECU.
the 96-97 ecu's are the same and the 98-99 are the same. the car should of passed with a 96 ecu since the car is a 96 itself.
Re: Help Needed! Car wont pass BAR inspection! (smart monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smart monkey »</TD></TR><TR><TD CLASS="quote">the 96-97 ecu's are the same and the 98-99 are the same. the car should of passed with a 96 ecu since the car is a 96 itself. </TD></TR></TABLE>
Except the ref doesn't car what year the car is in this case. The ECU must match the engine that sits in the bay. Not the chassis that it resides in.
Just find somone with a newer ecu and barrow the cover or the complet ecu. Not positive on the jumper but I am sure they will turn you away. Or have your buddy call them and ask if the use of a jumper harness ok or not cause its not worth going to them and being turnd away because of it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infinkc »</TD></TR><TR><TD CLASS="quote">would the pass the car with a 99 ecu and an obd2b-obd2a harness adaper?</TD></TR></TABLE>
Not the visual test.
