wiring 96 h23 external coil dizzy into 95 cx hatch using cx harness
just as the title says, im looking for info on wiring a 96 odb2 external coil dizzy into a 95 cx hatchback using the cx engine harness.
also, will i need to wire in the injector resistor box? i read on here in archived posts that obd2 injectors do not need a resistor box. if it is needed, can anyone shed any light on how to wire that also? thanks
Re: wiring 96 h23 external coil dizzy into 95 cx hatch using cx harness (BADEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaZvic »</TD></TR><TR><TD CLASS="quote">EXTERNAL IGNITION COIL will have 3 wires coming out of it. 2 connect to the distributor and 1 goes to a power source.:
GRN@coil, GRN@dizzy - connects coil to dizzy
YEL@coil, BLK/YEL@dizzy- connects coil to dizzy (should be a LARGE wire)
BLK/YEL - connects coil to power source.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lobus »</TD></TR><TR><TD CLASS="quote">also, will i need to wire in the injector resistor box? i read on here in archived posts that obd2 injectors do not need a resistor box. if it is needed, can anyone shed any light on how to wire that also? thanks</TD></TR></TABLE>
If the motor/injectors is a 92-96, you need a resister box, 97+ you do not.
b18c5eg
12-23-2002 02:22 PM
