h22 to b series tranny
Can someone send me info on what this adapter plate includes. if the B-series trans is used, is there any cutting involved with this engine swap? I want to drop this h22 I have into my crx, and can fab alot of parts, but was wondering about the fron traction control bracket. alot of the info on this subject is very scattered.
Thanks,
AV
Thanks,
AV
Guest
Posts: n/a
Re: h22 to b series tranny (tonyguns)
The radius rods are the least of your worries.If you use an adapter plate.You will have to cut the whole corner off the block to clear the axle and part of the pan rail.then you will have to make a bearing support for the half shaft.Then motor mounts and an oil pan.Oh yeah can't forget a custom header.Other than that it falls right in.
ExplicitSpeed
11-13-2004 10:09 PM
