h22 in 97 acura cl
h22 in 97 acura cl
i was wondering if anyone ever did this swap? well my main question is i have a cl with a h22 motor and whenever i brake the car seems to shake any ideas on what might be wrong?
Re: h22 in 97 acura cl (deca)
if its a 2.2cl aor 2.3cl its a direct drop in. you just need the motor, trans, and ecu. shift linkage, axles, harness, and motor mounts are up to snuff. if its a 3.0cl its just a ******* waste of time dont even bother. if u have anymore questions ask the accord guys b/c the cl and the accord are virtually the same damn car
You have an H22 in the CL? The problem is that when you apply the brakes the car shakes? Have you checked the rotors? Are all of your motor mounts torqued properly? What ECU did you use?
Jason
Jason
Re: h22 in 97 acura cl (FSTASNTZ)
im gonna check my rotors when i wake up, and check my totque spec for motor mount 2, and im running a standalone system
oh sorry i read that wrong. the motor and brakes dont have a damn the to do with eachother. i had the same problem, your brake rotors are worped like ****. replace them!!! its simple as that. if you are smart enough 2 put a h22 swap in a cl your smart enough 2 figure that out. the torque on your motor mounts and stand alone dont have **** in common with breaks. if your having trouble when you are breaking your car it has to do with breaks. not motormount or stand alone
