obd1 motor swaping in an obd2 head
i got a chance to get a ported and polished head with some sweet cams for free if i give him my gsr head (hes selling the motor so he would rather i get the head than some tool) problem is its an obd2 head. i was wondering if i can run my gsr obd1 ecu with an obd2 head, i want to keep it obd1 because its easer to tune, work on etc..., if i cant run that computer than is it possible to swap out att the wiring on the head from mine to his or am i stuck with either my head or swaping to obd2?
Re: (phantom grey eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phantom grey eg »</TD></TR><TR><TD CLASS="quote">so i can just use the distributer and injectors out of my head i got now right?
It is easier to swap then out for your OBD1 injectors and distributor then rewire for them.
If the new head you are getting is a gsr head, just swap the distributor and complete intake manifold(including injectors and all sensors) onto the new head.
If its a b16 or itr head, then you need to use the b16/itr intake manifold, but reuse you obd1 injectors and distributor. You'll also want to get the b16/itr throttle cable and intake.
