torque specs
Old Jan 14, 2005 | 11:16 AM
importlegions's Avatar
Default torque specs
i have to put a clutch/flywheel back on my d15b so i can swap it in, i need to kno the tourq specs for the flywheel,pressure plate, and transmission bolts(the ones to the block) thanks
Old Jan 14, 2005 | 12:17 PM
KNIVES's Avatar
Default Re: torque specs (importlegions)
honda hook up has manuals online. check there for tq specs
Old Jan 14, 2005 | 12:22 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importlegions &raquo;</TD></TR><TR><TD CLASS="quote">i have to put a clutch/flywheel back on my d15b so i can swap it in, i need to kno the tourq specs for the flywheel,pressure plate, and transmission bolts(the ones to the block) thanks</TD></TR></TABLE>
This diagram & specs is for B-series, but you can apply it to your D-series flywheel:
Old Jan 14, 2005 | 12:29 PM
Default Re: torque specs (K@man)
thanks, ne one kno bout the pressure plate tho? and can i put in the clutch plate and just line it up without using the alignment tool?
Old Jan 14, 2005 | 01:07 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importlegions &raquo;</TD></TR><TR><TD CLASS="quote">thanks, ne one kno bout the pressure plate tho? and can i put in the clutch plate and just line it up without using the alignment tool?</TD></TR></TABLE>
found the torque specs here:
http://www.binghamtonlife.com/...3.jpg
you don't have to use the clutch alignment tool, you can just eyeball it and hold it here with some other tool while bolting down the pressure plate..
Old Jan 14, 2005 | 01:43 PM
thanks man, ur really helpin me out here!
Old Jan 14, 2005 | 02:06 PM
Katman's Avatar
NP.
1QwIkEf
Sep 9, 2007 09:07 PM
My_EFsedan
Jun 14, 2007 08:47 PM
JDM-97CX
Oct 23, 2004 01:56 PM
Ben18C
Apr 21, 2004 03:06 PM
Benny Z
Oct 14, 2003 05:19 PM
