Shift linkage... HElP
Old Jan 12, 2005 | 01:14 AM
mdj_ge's Avatar
Default Shift linkage... HElP
Swapping a GSR in a 92 EG hatch... what shiftlinkage do i use... is the SOHC Linkage compatible with the B series... BTW i have a 97 JDM Type R Tranny... also is the linkage for the type r same as the GSR... HElp
Old Jan 12, 2005 | 04:33 AM
projectegr's Avatar
Default Re: Shift linkage... HElP (yangja)
Use the b-series shift linkage and pop the civic shifter (2 10mm and a pair of grips) onto the gsr/type-r linkage. Either b-series linkage should work, I'm pretty sure they are identical. Also on the stabilizer bar, there is a counter weight at the end (right next to the shifter on the shift linkage, cut it off or you will possibly get metal-on-metal grinding noise in your shifting. A Hack saw will do it or a torch if you have one. Should take no longer then 5 minutes tops. I do not have any pics, sorry. The counter weight is obvious though.
jD
You might be able to use the GSR shifter, I've never tried, as I've always wanted my stock civic shifter feel. Plus the man recommended it changed, so I did.
Old Jan 12, 2005 | 11:50 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yangja &raquo;</TD></TR><TR><TD CLASS="quote">Swapping a GSR in a 92 EG hatch... what shiftlinkage do i use... is the SOHC Linkage compatible with the B series... BTW i have a 97 JDM Type R Tranny... also is the linkage for the type r same as the GSR... HElp</TD></TR></TABLE>
You CANNOT use a D-series (SOHC) linkage with a B-series swap, totally incompatible.
You need to use a B-series shift linkage from one of the vehicles listed below and it should come with a shift lever when you get one. You shouldn't have to swap your SOHC shift lever over like the fella above mentioned:
- 94-01 integra (any 5-speed model)
- 99-00 civic Si
Old Jan 12, 2005 | 03:14 PM
mdj_ge's Avatar
Default Re: Shift linkage... HElP (K@man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K@man &raquo;</TD></TR><TR><TD CLASS="quote">
- 99-00 civic Si
Thanks a whole lot...
sextav6
Jul 10, 2009 09:46 AM
Cookiegsr
Apr 26, 2009 02:40 PM
hatchydude
Jul 14, 2006 11:50 AM
Touge Tuning
Dec 2, 2005 07:00 AM
Luserkid
11
Jun 30, 2004 04:17 PM
