Can this head work on a B16A2 Block
Old Jan 24, 2005 | 03:40 PM
02RSXS's Avatar
Default Can this head work on a B16A2 Block
I have a head off of an older integra I think its off a B17 GSR motor it is a vtec head and the casting number is PR3-4. I was wondering if that head will bolt up to a 2000 B16A2 block with little or no modifications and will the car run fine after? Are the cams the same and will this head change the compression ratio? The reason I am doing this is because the head is free and my brother's head is junk the timing belt was over tightened and the cams, bridges, and head are now all junk. I did a seach and couldn't find anything about anyone doing this thats why I posted it. Also the casting number off the 2000 B16A2 head is PR3-2 if that helps. Any feed back would be very helpful. Thanks.
Old Jan 24, 2005 | 04:36 PM
Chase's Avatar
Default Re: Can this head work on a B16A2 Block (02RSXS)
yes it will fit perfect
Old Jan 24, 2005 | 07:01 PM
VTECVillain's Avatar
Default Re: Can this head work on a B16A2 Block (b16crxkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16crxkid &raquo;</TD></TR><TR><TD CLASS="quote">yes it will fit perfect </TD></TR></TABLE>
Yup, bolt it up and you'll basically have a stock B16A2 again.
Old Jan 25, 2005 | 02:17 PM
02RSXS's Avatar
Thanks for your help I will use it then.
packman5280
Apr 10, 2008 06:15 AM
packman5280
Dec 27, 2007 08:09 AM
Turbo_y8
Feb 25, 2006 07:11 PM
99RedSi
Mar 1, 2005 12:57 PM
