B18c1 into 99 Civic Coupe
which are the most recommended mounts to use? ... I don't want to use the stock ones though...
http://hasport.com/catalog/pro...id=45
http://www.enjoracing.com/product_details.php?id=5
http://silverimageracing.com/p...t.cfm
There's Hasport, Enjo or Hayame. Hasport's version are just stock replacements for the 96-00 Civic and needs a bracket swap, according to their site ... but it doesn't say which bracket and they sell 3 of them or so ...
Enjo's looks like it only mounts to 2 places ...
can't see what's wrong with Hayame's ... probably nothing ?
any recommendations?
Re: B18c1 into 99 Civic Coupe (aznboysrfr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznboysrfr »</TD></TR><TR><TD CLASS="quote">I don't want to use the stock ones though...</TD></TR></TABLE>
Any reason why you don't want to use stock mounts other than you just don't want to?
Re: B18c1 into 99 Civic Coupe (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain »</TD></TR><TR><TD CLASS="quote">
Any reason why you don't want to use stock mounts other than you just don't want to? </TD></TR></TABLE>
they're not polyurethane = wheel hop
Re: B18c1 into 99 Civic Coupe (holotta_eg)
i have the hasport mounts for b series into ek chassis. it came wiht the bracket you need to change the mount on the drivers side from the 96+civic style to the 94+teg and 92-95 civic style. even if you get the hasports, you will still need the si rear bracket and drivers side mount bracket.
honestly, if i were to do it again i would get just the oem si mounts as necessary and use es inserts or even 3m window weld. the 400+ i spent on the hasports could pay for my turbo....
zero-one
11-27-2005 08:17 PM
