K20A into EF9 Shift Linkage Question
i got the ctr cable type shift linkage with my jdm k20a swap.
my question is will i have to use that, or what?
i have a c's position shift lever for my ef9, and want to know if there is some way that i can use that?
car is full race only, no street duty.
- P
- P
Re: K20A into EF9 Shift Linkage Question (Primo.)
If you want to use the Civic shifter cables, you have to mount the shifter like the Ep3. Fastbrakes owner did that in his car. He reported that he actually like it.
If you want the shifter to be located at the stock position, you will need the RSX cables.. I see them used for $100 on here and my website.
A friend bought a pair from a salvage yard for $35 the other day.
Good luck,
Nikos
Good luck,
Nikos
TheMostSadistic
06-18-2003 11:08 AM
