question regarding obd0 and obd1 map sensors.
I have a delima regarding a map sensor. I pulled the throttlebody on my obd1 integra and was going to put it on my brothers 90 civic with b16a. Heres the problem, my b18c1 TB has the map screwed on the TB and my brothers map is on the firewall and has a hose going to the TB. How can I make the obd0 map work or how can I make the obd1 map work?
thanks
thanks
Re: question regarding obd0 and obd1 map sensors. (dpine)
You can either run a vacuum line from the intake manifold to the map sensor on the firewall, or you can extend the harness and plug in the map sensor on the throttle body..
Either way will work fine..
Re: question regarding obd0 and obd1 map sensors. (locash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash »</TD></TR><TR><TD CLASS="quote"> or you can extend the harness and plug in the map sensor on the throttle body..
Either way will work fine.. </TD></TR></TABLE>
other than extending the wiring do I have to repin the plug?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpine »</TD></TR><TR><TD CLASS="quote">
other than extending the wiring do I have to repin the plug?</TD></TR></TABLE>
No.
No.
SiMateoAko
03-23-2006 08:22 PM
