did i do this right
Old Jan 22, 2005 | 10:29 AM
DFW's Avatar
DFW
Default did i do this right
just installed and bled my radiator
filled the radiator fluid to the top with the cap off, turned on my car squeezed the top radiator hose and saw all the air bubbles escape did this for 5 mins until the car reached normal operating temp. i had to add fluid once or twice but when i was done i had to barely add any at all, but i re-opened the cap and addded so more again, is that ok or do i have to re-do it now?
Old Jan 22, 2005 | 06:24 PM
Andres-eh2's Avatar
did you turn on the heater to make the coolant circulate?
Old Jan 23, 2005 | 11:01 AM
mrbsponge's Avatar
and definetley make sure the coolant resovoir is filled up to the full line, this will help in case you are low it will pull it into the radiator
Old Jan 28, 2005 | 11:36 PM
orng1's Avatar
Default Re: did i do this right (DFW)
sounds about right, but still check it later when the car is cold.
Old Jan 29, 2005 | 07:33 AM
stevescivic's Avatar
Default Re: did i do this right (orng1)
you might want to open up the air bleed screw valve on the top of the thermostat. Most hondas have them but I could be mistaken.
The thermostat should be the highest location on the engine thus that is where all the air in the cooling system will build up. By opening this valve up you are essentially purging the system. Do this when the engine is hot and open the valve with a 12mm socket really slowly so as not have coolant spray everywhere.
Good luck
Old Jan 29, 2005 | 07:57 AM
locash's Avatar
Default Re: did i do this right (stevescivic)
The thermostat on Honda's in located where the LOWER radiator hose meets the engine. The engines that do have air bleed valves normally have them on the port where the upper radiator hose meets the engine..
xlusiveracer
30
Feb 10, 2017 11:49 AM
B18c1vicrx
May 13, 2009 01:01 PM
dlo102106
Sep 28, 2007 03:44 PM
budget
Apr 9, 2005 10:31 AM
DFW
Jan 22, 2005 04:00 PM
