B16 si motor swap into 95 hb
simple question really...my 1.5 blew a piston in my 95 hatch and i have a couple motors that im choosing from. One is a b16 si motor and i was wondering if anyone knows how hard it would be and the changes i would need to make if i was to swap them
thanks for any info....
sezar
sezar
Re: B16 si motor swap into 95 hb (sezar95HB)
you need the rear mount off of a Integra and you need the front 2 mounts off a 99-00 Si or a Integra meaning the AC mount and the Tranny mount you then need a engine harness or you need to run the two wires for Vtec if you car is a DX the swap is easy takes me about 5 hours to take the stock motor out and put the B series in good luck
Re: B16 si motor swap into 95 hb (Lmgrcivic)
Well i got a B16A3 that i swapped it into my 92 HAtch SI, and i used a 99-00 SI bracket, and Ls axles, and i don't really care about the two side mount i just used the stock mount from my civic. Swapping a b series is easy man. Anybody could do it. Takes meeh a week because i had to go to work and my brother lag on meeh and didn't help meeh. So i did it myself. IF there's any thing else then holla @ meeh and i'll give you more info. You can do it??!?!!??!!?!
LsScivic
07-11-2009 12:31 PM
