NEED HELP ON A SWAP!!!
Old Jan 19, 2005 | 02:50 PM
JunTec's Avatar
Default NEED HELP ON A SWAP!!!
ok im swappin an OBD0 B18A to a JDM OBD1 B18B. Does anyone know how to convert a B18A wiringharnest to a B18B? would really areciate the help in advance...
Old Jan 26, 2005 | 11:03 AM
92_EGhatch's Avatar
Default Re: NEED HELP ON A SWAP!!! (JunTec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunTec &raquo;</TD></TR><TR><TD CLASS="quote">ok im swappin an OBD0 B18A to a JDM OBD1 B18B. Does anyone know how to convert a B18A wiringharnest to a B18B? would really areciate the help in advance...</TD></TR></TABLE>
TAke off the hardness from the B18A OBD0 and swapped it in the B18B. Since your car is a OBD0 then change the hardness and it'll plugged right in. You don't need the OBD1 engine hardness. GOOD LUCK
Old Jan 26, 2005 | 04:24 PM
JunTec's Avatar
Default Re: NEED HELP ON A SWAP!!! (92_EGhatch)
thankx
Old Jan 25, 2008 | 12:31 PM
integraswtrde's Avatar
tru story
Old Jan 26, 2008 | 03:50 PM
HondaPartsHero's Avatar
Technical Hero
swap over the B18a's injectors, distributor, alternator and fan switch and everything else should plug right in. Also on the B18B the map sensor should be on top of the throttle body so you won't use the one on the fire wall anymore. you also will want to use whatever exhaust manifold that is on the B18A for correct O2 placement.
Old Jan 26, 2008 | 09:57 PM
JunTec's Avatar
Default Re: NEED HELP ON A SWAP!!! (HondaPartsHero)
that car is long gone 3 years ago
2K4K20
May 1, 2006 09:11 AM
effinnwackk
21
Jul 1, 2005 05:50 AM
the.hamburglar
May 27, 2005 05:24 AM
CRXRTYPE
Aug 5, 2004 01:02 PM
gildo86
May 31, 2004 11:41 AM
