EG swap mounts?
EG swap mounts?
I did a search and came up with nothing. I was wondering if I could use the stock sohc for a B-series swap. I know I will need a b-series rear engine bracket. Can I use the stock rear mount, tranny mount, driverside mount, and the front under tranny mount?
What ever engine swap you get that is a B series, should bolt right up using the mounts that come with the engine...I reused the rubber mounts for the lower tranny mount and ac mount...Also I reused the rubber mount near the firewall from the civic...everything else has to be B Series...
Re: (jaybee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaybee »</TD></TR><TR><TD CLASS="quote">What ever engine swap you get that is a B series, should bolt right up using the mounts that come with the engine...</TD></TR></TABLE>
Let me get this straight...you're saying the top sohc tranny mount and driver side mount will not work with a B-series swap, but everything else (rear mount, ac mount, tranny vibration mount) that is sohc should work?
Re: (jaybee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaybee »</TD></TR><TR><TD CLASS="quote">Look what I found...
https://honda-tech.com/zerothread?id=351514</TD></TR></TABLE>
thanks. you are a sweet heart...may god bless your little soul
