why is my clutch sticking?
I have a 93 coupe ex with a jdm b16a with a type r tranny. i have a clutchmasters stage 3 clutch and a lightened flywheel. I have a hydrolic clutch. The clutch has been in for about 4000 miles with no problems. however just last night when i was driving, the clutch pedal would like stick down sometimes while shifting but it would come back up when i would let up on it. however a couple times at a traffic light it would stick down and i would have to reach down and pull it up with my hand, and then it would be fine for a little while. while its stuck down it feels like there is no pedal pressure. i have replaced the master cylinder and i bled it and bled it and bled it so i'm almost 100 percent sure that there isnt any air in the line, but when i was bleeding it after i pumped the pedal and then opened the bleed the pedal would get stuck down and i would have to pull it up then it would be fine, and thats almost how this feels, do you have any suggestions? let me know, thanks vernon
slave or a leak in your lines. had the same problem with my ek when I switched from auto to manual. I forgot to tighten one of the lines down so it was leaking.
I would say keep an eye on your fluid for a couple of days and if it doesn,t go down then replace or rebuild slave.
Re: (cherroneballs)
yep it was the slave cylinder, it went up on me that morning at school, luckily i had one off of my d series motor that i could put on it so i'm using that for now.
