shorter shift lever = quicker shifts?
ive been looking into getting a short thro stick and bushings blah blah blah and a friend of mine said that replacing the stock shift lever with a shorter one would also quicken up shifting. i did a search and i cant answer my question.
Re: shorter shift lever = quicker shifts? (Hyb)
Here's another opinion for you to factor in your decision:
http://www.fastlineperformance.com/shifter.htm
One of the H-T sponsor's (MrHeeltoe) sells them, you can probably find his thread and some comments/reviews.
Re: shorter shift lever = quicker shifts? (XrcR6)
it wont make for quicker shifts, it will just shorten the throw and give it much more positive shifts, gets rid of that spongy feeling that comes with a stock shifter
Re: shorter shift lever = quicker shifts? (phantom grey eg)
Actually it does shorten the throw between gears. Shorter shifter, shorter throws. Example: Shift with a 10 foot pole then shift with a 1/2 foot pole. Takes less time with the 1/2 foot pole. I don't recommend a 10 foot pole, but I used that size to prove a point.
Re: shorter shift lever = quicker shifts? (crxtreme89h)
im not talkin about a short throw shifter (as in the one u hold) im talkin about the little lever thats on the tranny that the shift linkage connects to.
crxzcracer
10
06-20-2004 09:54 PM
