WEIRD SWAP PROBLEM...
Old Jun 12, 2006 | 02:47 AM
NVturbo's Avatar
O.G. triple O.G.
Default WEIRD SWAP PROBLEM...
My cousin and I just got finished putting in an OBD2 LS swap into his 93 Civic coupe (OBD1 ecu). The problem: the car will not go into gear with the motor cranked/ON. With the engine OFF, it will go into gear. For example, if you crank it in 1st, it will move but won't allow you to change gears. We have removed the tranny to check the clutch, pressure plate, T/O bearings, forks and flywheel. Both axles are brand NEW. If you crank the car on jack stands, you are able to change gears. We have also bled the clutch. What can be the problem?????? He needs the car running ASAP. Thanks in advance.
Old Jun 12, 2006 | 07:21 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: WEIRD SWAP PROBLEM... (NVturbo)
....ANYONE???
Old Jun 12, 2006 | 07:34 AM
NVturbo's Avatar
O.G. triple O.G.
NEVER MIND.....PROBLEM SOLVED.
Old Jun 12, 2006 | 06:28 PM
ChampWhiteTegra's Avatar
problem was?
Old Jun 14, 2006 | 06:32 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: (ChampWhiteTegra)
He needed to adjust his clutch pedal play. Shiet happens!!
pink94coupe
Transmission & Drivetrain
Oct 2, 2013 03:49 AM
fkguitar
Feb 22, 2007 04:41 AM
arrogant_
Jan 9, 2005 04:20 PM
BLK99VTECR
Aug 20, 2004 09:24 PM
Dorikamu
Nov 6, 2002 07:46 PM
