EX ECU ON LS MOTOR...WILL IT AFFECT THE PEFORMANCE?
I have a 2000 ls motor but no ls ecu.I was wondering if an obd1 ex ecu will affect the performance of the motor?By the way its going into an eg... if that helps at all. THANKS!
Re: EX ECU ON LS MOTOR...WILL IT AFFECT THE PEFORMANCE? (L`DC2)
of course it will affect performance. Your running an ECU that was meant for a 1.6l motor. Chip the ecu(I assume it a p28)and put a stock LS program on it.
Re: EX ECU ON LS MOTOR...WILL IT AFFECT THE PEFORMANCE? (fastwanabe)
You would also be constantly throwing codes for vtec solenoid and vtec oil pressure sensor.
Re: EX ECU ON LS MOTOR...WILL IT AFFECT THE PEFORMANCE? (Slopoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke »</TD></TR><TR><TD CLASS="quote">You would also be constantly throwing codes for vtec solenoid and vtec oil pressure sensor.</TD></TR></TABLE>true.... I forgot about that. Just get a p75 ECU and do it the right way.
