USDM ITR Tranny W/ JDM FD Kit
I had this transmission in my previous USDM original ITR. I have since sold the car and bought an EG hatch to which I swapped in a 98+ spec JDM ITR engine/tranny combo from http://www.hmotorsonline.com
My question is this: is the gearing on my old Type R the EXACT same as the USDM ITR transmission with the JDM FD kit? I thought I remember reading where the 1-3 gears were the same and that 4th and 5th fell off on my current setup compared to what I used to have in my ITR.
Can anyone shed some light on this? I am in the process of building up the transmission for HPDE days and it feels as though the 4th gear really is tall on the straightaways.
Thanks
Thanks
Re: USDM ITR Tranny W/ JDM FD Kit (EleanoR)
Umm, 98+ JDM ITR tranny has a different 4th and 5th. It is 1.034 VS 1.107 for 4th and 0.787 VS 0.848 for 5th. Does that answer your ?
Re: USDM ITR Tranny W/ JDM FD Kit (brokeHonda)
That makes absolutely perfect sense. I would like to change the 4th and 5th gear on my JDM ITR transmission to the USDM version. Do I just need to buy the gears themselves from Acura or do I need other parts?
Yep. Is the car falling on its face when you shift up to 4th? Also, the higher 5th will make DD a >4000rpm adventure!
yes it does. it takes literally forever to get through 4th it seems like. the car is a full HPDE car. doesn't see street whatsoever. i don't care about highway RPMS because it's never on the highway
I am going to be putting the ATS 4.92 FD in soon so I wanted to make sure I had the correct 4th and 5th gears. I am assuming I can just call up Acura and get these gears (USDM version of course) and switch them along with the FD all at the same time.
Mike
Mike
Re: USDM ITR Tranny W/ JDM FD Kit (96 SOHC VTEC)
ALright chief, here is the online store where I buy from: http://www.acuraoemparts.com/delray/jsp/home.jsp
You'll need the 4th and 5th gear from the USDM type-r for the mainshaft and countershaft!
Good luck!
Good luck!
euclid
05-03-2003 12:21 PM
