B16B vs B16A?!?!?!
Old Jun 14, 2006 | 05:35 AM
tobe1424's Avatar
Default B16B vs B16A?!?!?!
Is there any difference in the block...the stroke...or is it just the head that the b16b gets that extra juice....I thought that the b16b utilizes the same block as the gsr and type r making me able to put a b18 bottom end unlike a b16a that is 6mm shorter....help me out here.
Old Jun 14, 2006 | 06:36 AM
99 Civic EX's Avatar
Default Re: B16B vs B16A?!?!?! (tobe1424)
the b16b is just a destroked itr motor, so to amke it into a 1.8 you can use the itr crank and connecting rods and you'll actually be pushing more torque then an itr would with the ctr pistons.
Old Jun 14, 2006 | 06:40 AM
ZacCarter's Avatar
/thread
Old Jun 14, 2006 | 06:53 AM
B_Something's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tobe1424 &raquo;</TD></TR><TR><TD CLASS="quote">Is there any difference in the block...the stroke...or is it just the head that the b16b gets that extra juice....I thought that the b16b utilizes the same block as the gsr and type r making me able to put a b18 bottom end unlike a b16a that is 6mm shorter....help me out here.</TD></TR></TABLE>
I actually had a B16B in my 98'CX Hatch, it was very close if not the same as a B16A until 6K RPMs. From 6K to 8600K it was the most beautiful sounds I have ever heard. As far as the block, it does share the same deck as the GSR, those are the parts we used during install,i.e. timing belt, water pump etc. The cylinder head is hand ported and polished and has more aggressive cams, intake manifold, and throtlle body (I think).
By far beats the **** out of B16A stock vs. stock. The trans is very nice and close ratios like the ITR, mine was 4.4 FD and they all come with LSD.
I def. wanted to upgrade to the Spoon 1.8L stroker kit, but chose otherwise. I really did not want to comprimise the most unique B series motor ever produced in my mind.
Old Jun 14, 2006 | 07:00 AM
Boostage's Avatar
Default Re: B16B vs B16A?!?!?! (B_Something)
it revs to 8600 stock?
Old Jun 14, 2006 | 07:01 AM
Default Re: B16B vs B16A?!?!?! (Boostage)
yes, it's ridiculous.
Old Jun 14, 2006 | 08:05 AM
Boostage's Avatar
does it use the same springs and retainers as ITR's?
ZacCarter's Avatar
Yes.
Old Jun 14, 2006 | 09:29 AM
tobe1424's Avatar
so you had to piston to valve clearance issues when putting in the 1.8 bottom end....so then its only the B16A that has a 6mm or so shorter block than all the other b motors
Old Jun 14, 2006 | 09:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tobe1424 &raquo;</TD></TR><TR><TD CLASS="quote">so you had to piston to valve clearance issues when putting in the 1.8 bottom end....so then its only the B16A that has a 6mm or so shorter block than all the other b motors</TD></TR></TABLE>
Not sure who you are talking to, but a stroker kit that I was referring to was not installed. If it were it is only internal, no block changes.
I believe that the B16A is a shorter block yes.
Hope that helps.
Old Jun 14, 2006 | 09:19 PM
tobe1424's Avatar
wow I keep on finding out weird things....is the JDM B16A block the same deck hight as the B16B making the USDM B16A the only short one...or is that a typo that I read?
Old Jun 14, 2006 | 09:42 PM
super_nguyen's Avatar
the only b16 with a tall block is the b16B, all others (jdm or usdm) have the shorter block
Old Jun 15, 2006 | 05:52 AM
tobe1424's Avatar
Default Re: B16B vs B16A?!?!?! (super_nguyen)
damn.....anyone else out there to prove this fact..........with some evidence preffered......................................... ..........................................
Old Jun 15, 2006 | 06:05 AM
noboostedEGo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super_nguyen &raquo;</TD></TR><TR><TD CLASS="quote">the only b16 with a tall block is the b16B, all others (jdm or usdm) have the shorter block </TD></TR></TABLE>
^^^This is correct^^^
If you want more evidence, research it, it's everywhere, i've probably seen about 5 of these threads in the past month, and i don't even look for them.
B16A JDM EG
20
Nov 18, 2006 05:49 AM
DC2 Mang
12
Mar 9, 2006 05:47 PM
Mohsin
13
Nov 6, 2005 02:14 PM
wrXtian
41
Apr 23, 2003 01:11 PM
H22CIVIC
Oct 2, 2001 11:45 AM
